Aller au contenu principal
Lenovo Thinkpad T450s Motherboard Replacement
Ce dont vous avez besoin
  1. Lenovo Thinkpad T450s Motherboard Replacement, Fan: étape 1, image 1 de 1
    • Flip the laptop over so that the bottom is facing up.
    • Unlock the battery by sliding the keys outwards. When unlocked, push the battery forwards to remove.
  2. Lenovo Thinkpad T450s Motherboard Replacement: étape 2, image 1 de 1
    • Unscrew all 3.7 mm Phillips #0 screws from the back of the laptop. Half of them will remain attached to the cover.
    • Lift off the back cover.
  3. Lenovo Thinkpad T450s Motherboard Replacement: étape 3, image 1 de 1
    • Unscrew the four 5 mm Phillips #0 screws that secure the heatsink.
    • The screws will remain attached.
    • The Fan is attached to the heat sink assembly.
  4. Lenovo Thinkpad T450s Motherboard Replacement: étape 4, image 1 de 1
    • Use a plastic opening tool or a nylon spudger to push the fan's bundled cable connector free.
    • Remove the fan and heat sink assembly from the motherboard.
  5. Lenovo Thinkpad T450s Motherboard Replacement, Motherboard: étape 5, image 1 de 1
    • Remove all twelve 3.6 mm Phillips #00 screws.
  6. Lenovo Thinkpad T450s Motherboard Replacement, Remove the Hard Drive: étape 6, image 1 de 2 Lenovo Thinkpad T450s Motherboard Replacement, Remove the Hard Drive: étape 6, image 2 de 2
    • Remove the hard drive from the motherboard's by gently pulling it out and up at the same time.
  7. Lenovo Thinkpad T450s Motherboard Replacement: étape 7, image 1 de 1
    • Pull out the socket that is attached to the left side of the battery case.
  8. Lenovo Thinkpad T450s Motherboard Replacement: étape 8, image 1 de 1
    • Unplug the cable that attaches the polymer battery to the motherboard by pulling it out carefully.
  9. Lenovo Thinkpad T450s Motherboard Replacement: étape 9, image 1 de 1
    • Remove the ribbon cable attached to the the battery case carefully by pulling the cable up and out.
  10. Lenovo Thinkpad T450s Motherboard Replacement: étape 10, image 1 de 1
    • Remove the motherboard from the case. If the motherboard does not come off the case or feels stuck, make sure that you have removed all the cables prior
2 autres ont terminé cette réparation.
Sara Karimi Razakani
Membre depuis le 03/31/22
178 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team 2-3, Harley Spring 2022 Membre de l'équipe IUPUI, Team 2-3, Harley Spring 2022
IUPUI-HARLEY-S22S2G3
3 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 46
Total : 1,271
