Aller au contenu principal
Pièces
Aucune pièce spécifiée.
  1. Lenovo Thinkpad x230 Keyboard Replacement, Preparations: étape 1, image 1 de 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
  2. Lenovo Thinkpad x230 Keyboard Replacement, Locate the battery: étape 2, image 1 de 1
    • Flip the computer upside down.
    • The red rectangle shows the location of the battery.
  3. Lenovo Thinkpad x230 Keyboard Replacement, Unlock the left switch: étape 3, image 1 de 3 Lenovo Thinkpad x230 Keyboard Replacement, Unlock the left switch: étape 3, image 2 de 3 Lenovo Thinkpad x230 Keyboard Replacement, Unlock the left switch: étape 3, image 3 de 3
    • Locate the two switches that lock the battery. Push the left-hand switch outward into the "unlocked" position.
  4. Lenovo Thinkpad x230 Keyboard Replacement, Remove the battery: étape 4, image 1 de 3 Lenovo Thinkpad x230 Keyboard Replacement, Remove the battery: étape 4, image 2 de 3 Lenovo Thinkpad x230 Keyboard Replacement, Remove the battery: étape 4, image 3 de 3
    • Now push and hold the right clip to the right while using your other hand to gently slide the battery away from the computer.
  5. Lenovo Thinkpad x230 Keyboard Replacement, remove screws: étape 5, image 1 de 3 Lenovo Thinkpad x230 Keyboard Replacement, remove screws: étape 5, image 2 de 3 Lenovo Thinkpad x230 Keyboard Replacement, remove screws: étape 5, image 3 de 3
    • There are 2 screws securing the keyboard. You can identify them by a small keyboard symbol (marked by an orange rectangle in the second picture).
    • Once you have located the two screws, remove them with a small Phillips screwdriver.
  6. Lenovo Thinkpad x230 Keyboard Replacement, remove strip above keyboard: étape 6, image 1 de 3 Lenovo Thinkpad x230 Keyboard Replacement, remove strip above keyboard: étape 6, image 2 de 3 Lenovo Thinkpad x230 Keyboard Replacement, remove strip above keyboard: étape 6, image 3 de 3
    • This step is not required.
    • Gently pull the strip out from the case.
  7. Lenovo Thinkpad x230 Keyboard Replacement, pop keyboard out of the casing: étape 7, image 1 de 2 Lenovo Thinkpad x230 Keyboard Replacement, pop keyboard out of the casing: étape 7, image 2 de 2
    • Use a a plastic spudger (or a flat screwdriver) to push the keyboard towards the screen. This will pop the bottom of the keyboard out of the casing.
  8. Lenovo Thinkpad x230 Keyboard Replacement, lift keyboard: étape 8, image 1 de 2 Lenovo Thinkpad x230 Keyboard Replacement, lift keyboard: étape 8, image 2 de 2
    • Carefully lift the keyboard so that you can access its connector.
  9. Lenovo Thinkpad x230 Keyboard Replacement, Unplug keyboard: étape 9, image 1 de 2 Lenovo Thinkpad x230 Keyboard Replacement, Unplug keyboard: étape 9, image 2 de 2
    • Carefully unplug the connector by pulling.
  10. Lenovo Thinkpad x230 Keyboard Replacement, done: étape 10, image 1 de 1
    • You are done - the keyboard is not connected to the laptop any more and can be replaced.
8 autres ont terminé cette réparation.
Johannes
Membre depuis le 25/02/2014
983 Réputation
3 tutoriels rédigés
4 commentaires
Very good instructions. Really easy. Difficulty rather easy than moderate. Took me two minutes.
Carsten Mühlberg - Réponse
How do I reinsert the strip above the keyboard? When I insert the bottom clips first I can’t get the top ones in and vice versa. Also I don’t understand the mechanism of the top clips, why do they have the shape they do?
Daan - Réponse
Worked perfectly. It was easy enough that I could use a key ring screw driver
Chris Barry - Réponse
Quisiera saber cómo reparar el teclado ya que está en corte y no me deja encender la laptop
Mario Sánchez Soroa - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 24
30 derniers jours : 102
Total : 8,334
