Introduction
This guide will solve issues involving a defective battery, such as: Unexpected Shutdown, Laptop not Charging, Laptop Shuts down when Unplugged.
Ce dont vous avez besoin
Flip the device so the back is facing you.
Using the Phillips #0 screwdriver, unscrew the fourteen screws from the device.
Use the Phillips #0 screwdriver to unscrew the three screws holding the battery.
Outil utilisé dans cette étape :Tweezers$4.99
Use the Blunt Tweezers from the Tool Kit to disconnect the battery connections from the motherboard.
Remove the battery from the device.
To reassemble your device, follow the instructions on Step 3.
2 autres ont terminé cette réparation.
