Aller au contenu principal
Lenovo Touch Y70-70 Motherboard Replacement
Ce dont vous avez besoin
  1. Lenovo Touch Y70-70 Motherboard Replacement, Motherboard: étape 1, image 1 de 1
    • Flip the device so that the back cover is facing you.
    • Using the Phillips #0 screwdriver, remove 14 screws from the back of the device.
  2. Lenovo Touch Y70-70 Motherboard Replacement: étape 2, image 1 de 3 Lenovo Touch Y70-70 Motherboard Replacement: étape 2, image 2 de 3 Lenovo Touch Y70-70 Motherboard Replacement: étape 2, image 3 de 3
    • Using the Phillips #0 screwdriver, remove the three screws holding down the battery.
  3. Lenovo Touch Y70-70 Motherboard Replacement: étape 3, image 1 de 2 Lenovo Touch Y70-70 Motherboard Replacement: étape 3, image 2 de 2
    • Using the Phillips #0 screwdriver, remove the metal reinforcement by removing the three screws.
  4. Lenovo Touch Y70-70 Motherboard Replacement: étape 4, image 1 de 3 Lenovo Touch Y70-70 Motherboard Replacement: étape 4, image 2 de 3 Lenovo Touch Y70-70 Motherboard Replacement: étape 4, image 3 de 3
    • Using the Phillips #0 screwdriver, carefully remove the three screws holding down the fan.
    • Detach the cables connecting the fan to the motherboard.
  5. Lenovo Touch Y70-70 Motherboard Replacement: étape 5, image 1 de 2 Lenovo Touch Y70-70 Motherboard Replacement: étape 5, image 2 de 2
    • Using the Phillips #0 screwdriver, remove the six screws holding down the cooling unit.
  6. Lenovo Touch Y70-70 Motherboard Replacement: étape 6, image 1 de 2 Lenovo Touch Y70-70 Motherboard Replacement: étape 6, image 2 de 2
    • Remove the Ethernet port by unscrewing the two screws holding it down.
  7. Lenovo Touch Y70-70 Motherboard Replacement: étape 7, image 1 de 2 Lenovo Touch Y70-70 Motherboard Replacement: étape 7, image 2 de 2
    • Unplug the various cables attached to the motherboard using your fingers carefully.
    • Detach the cables using your fingers.
  8. Lenovo Touch Y70-70 Motherboard Replacement: étape 8, image 1 de 3 Lenovo Touch Y70-70 Motherboard Replacement: étape 8, image 2 de 3 Lenovo Touch Y70-70 Motherboard Replacement: étape 8, image 3 de 3
    • Finally, remove the six screws holding down the motherboard.
    • Remove the motherboard from the laptop.
Mohammed Motorwala
Membre depuis le 11/07/19
298 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S2-G5, Harley Fall 2019 Membre de l'équipe IUPUI, Team S2-G5, Harley Fall 2019
IUPUI-HARLEY-F19S2G5
2 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 22
Total : 984
