Aller au contenu principal
Lenovo V14 G2 ALC RAM Replacement
Ce dont vous avez besoin
    • First, power off the laptop ( hold the power button for 5 sec)
  1. Lenovo V14 G2 ALC RAM Replacement, Opening: étape 2, image 1 de 1
    • Next step, close the lid and put the laptop upside down and unscrew all these screws with a philips head screwdriver.
  2. Lenovo V14 G2 ALC RAM Replacement, Prying: étape 3, image 1 de 1
    • Insert the pry tool/guitar pick in the top center of the laptop and create an gap then slide the pry tool or the guitar pick till you hear plastic cracking
  3. Lenovo V14 G2 ALC RAM Replacement, Continue prying from the corners: étape 4, image 1 de 1
    • Now continue prying from the corners and the back panel should came off pretty easily.
  4. Lenovo V14 G2 ALC RAM Replacement, Lifting the back panel: étape 5, image 1 de 1
    • Lift the panel from the top and you will have access to the motherboard
  5. Lenovo V14 G2 ALC RAM Replacement, Discovering the RAM cover: étape 6, image 1 de 1
    • This is the ram cover that you need to get open.
  6. Lenovo V14 G2 ALC RAM Replacement, Opening the ram cover: étape 7, image 1 de 2 Lenovo V14 G2 ALC RAM Replacement, Opening the ram cover: étape 7, image 2 de 2
    • You have these clips around the cover, bend them slowly so you can lift up the cover
  7. Lenovo V14 G2 ALC RAM Replacement, Inserting the RAM module: étape 8, image 1 de 1
    • Make sure to install the ram module correctely according to the pins and press down on the ram module till you hear a click.
  8. Lenovo V14 G2 ALC RAM Replacement, Assembling: étape 9, image 1 de 1
    • Put the ram cover back on and bend the pins back
    • Put the cover back on but don't screw it in yet, just press on it lightly and powerup your laptop and see if the ram works, open taskmanager -> performance or enter the bios and check the amount of mb
    • Put the cover back on and be careful when putting the screws because the little screws need to be screwed in the bottom part of the laptop and the big ones need to be screwed in the top and middle part!
    • Have fun!
To reassemble your device, follow these instructions in reverse order. It's easy
Mihai Victor
Membre depuis le 07/20/23
230 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 20
Total : 190
