Aller au contenu principal
Lenovo V14-ADA Screen Replacement
Ce dont vous avez besoin
  1. Lenovo V14-ADA Screen Replacement, Back Panel: étape 1, image 1 de 1
    • Turn off the laptop.
    • Disconnect the charging cable from the laptop.
    • Failure to unplug the cable could result in electric shock.
    • Flip the laptop upside down.
  2. Lenovo V14-ADA Screen Replacement: étape 2, image 1 de 1
    • Remove all ten 5 mm screws from the back panel using a JIS #0 screwdriver.
  3. Lenovo V14-ADA Screen Replacement: étape 3, image 1 de 2 Lenovo V14-ADA Screen Replacement: étape 3, image 2 de 2
    • Place the Jimmy in the small crack between the back panel and the keyboard and push down.
    • Repeat this until the panel pops off.
  4. Lenovo V14-ADA Screen Replacement, Battery: étape 4, image 1 de 2 Lenovo V14-ADA Screen Replacement, Battery: étape 4, image 2 de 2
    • Remove the four 3 mm screws surrounding the battery using a JIS #0 screwdriver.
    • Slightly pull on the black wire connector to unplug the battery.
    • Lift up the battery to remove it from the laptop.
  5. Lenovo V14-ADA Screen Replacement, Screen: étape 5, image 1 de 3 Lenovo V14-ADA Screen Replacement, Screen: étape 5, image 2 de 3 Lenovo V14-ADA Screen Replacement, Screen: étape 5, image 3 de 3
    • Remove the four 3 mm screws on the hinges on both sides of the back of the laptop.
    • Use the Jimmy to pop the surrounding screen bezel off.
  6. Lenovo V14-ADA Screen Replacement: étape 6, image 1 de 2 Lenovo V14-ADA Screen Replacement: étape 6, image 2 de 2
    • Remove the two 3 mm screws at the top two corners of the screen using a JIS #0 screwdriver.
  7. Lenovo V14-ADA Screen Replacement: étape 7, image 1 de 1
    • Remove the screen from the laptop.
Samaya Roukoz
Membre depuis le 03/19/24
253 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-2, Shaddix Spring 2024 Membre de l'équipe UMass Dartmouth, Team 4-2, Shaddix Spring 2024
UMASSD-SHADDIX-S24S4G2
5 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 14
30 derniers jours : 28
Total : 186
