Aller au contenu principal
Lenovo V15-ADA Hard Disk Drive (HDD) Replacement
Ce dont vous avez besoin
  1. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement, Back Panel Assembly: étape 1, image 1 de 1
    • Remove the 10 marked screws using a Phillips #1 screwdriver bit.
    • M2.5 × 7 mm, Phillips-head (6) (RED circles)
    • M2.5 × 4 mm, Phillips-head (4) (ORANGE circles)
  2. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: étape 2, image 1 de 1
    • Remove the 10 screws from the back plate.
  3. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: étape 3, image 1 de 1
    • After all 10 screws have been removed, insert a spudger between the bottom plate and the housing and slide across.
    • Repeat for all 4 sides until loose.
  4. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: étape 4, image 1 de 1
    • Pop off the back plate and set aside.
  5. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement, Battery: étape 5, image 1 de 3 Lenovo V15-ADA Hard Disk Drive (HDD) Replacement, Battery: étape 5, image 2 de 3 Lenovo V15-ADA Hard Disk Drive (HDD) Replacement, Battery: étape 5, image 3 de 3
    • To start the removal of the battery, disconnect the ribbon cable connecting the battery to the computer.
  6. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: étape 6, image 1 de 3 Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: étape 6, image 2 de 3 Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: étape 6, image 3 de 3
    • The battery is held in place by 3 screws. Use the Phillips #0 screwdriver to remove the screws that secure the battery.
    • M2 × 6 mm, Phillips-head, nylok-coated (3)
  7. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: étape 7, image 1 de 1
    • Remove the battery from the device after completing steps 1 and 2.
  8. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement, Hard-Disk Drive (HDD): étape 8, image 1 de 1
    • Attach a PH0 head onto the screwdriver and remove screw. (M2 × 6 mm, Phillips-head, nylok-coated)
  9. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: étape 9, image 1 de 1
    • Grasp the hard drive and lift up.
  10. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: étape 10, image 1 de 1
    • Pull the hard drive from its port.
  11. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: étape 11, image 1 de 1
    • The hard drive has been successfully taken out.
Jacob Schorr
Membre depuis le 02/21/24
433 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 18
Total : 65
