Aller au contenu principal
Lenovo V15-ADA Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. Lenovo V15-ADA Wi-Fi Card Replacement, Back Panel Assembly: étape 1, image 1 de 1
    • Remove the 10 marked screws using a Phillips #1 screwdriver bit.
    • M2.5 × 7 mm, Phillips-head (6) (RED circles)
    • M2.5 × 4 mm, Phillips-head (4) (ORANGE circles)
  2. Lenovo V15-ADA Wi-Fi Card Replacement: étape 2, image 1 de 1
    • Remove the 10 screws from the back plate.
  3. Lenovo V15-ADA Wi-Fi Card Replacement: étape 3, image 1 de 1
    • After all 10 screws have been removed, insert a spudger between the bottom plate and the housing and slide across.
    • Repeat for all 4 sides until loose.
  4. Lenovo V15-ADA Wi-Fi Card Replacement: étape 4, image 1 de 1
    • Pop off the back plate and set aside.
  5. Lenovo V15-ADA Wi-Fi Card Replacement, Wi-Fi Card: étape 5, image 1 de 1
    • Remove the Black wire with your fingers or small ESD-safe tweezers.
  6. Lenovo V15-ADA Wi-Fi Card Replacement: étape 6, image 1 de 1
    • Remove Grey wire.
  7. Lenovo V15-ADA Wi-Fi Card Replacement: étape 7, image 1 de 1
    • Unscrew screw holding Wi-Fi card in place.
    • 1x M2 x 3mm, Phillips #1.
  8. Lenovo V15-ADA Wi-Fi Card Replacement: étape 8, image 1 de 1
    • Card will lift up after screw is out of place.
  9. Lenovo V15-ADA Wi-Fi Card Replacement: étape 9, image 1 de 1
    • Pull Wi-Fi card out of slot.
Jacob Schorr
Membre depuis le 02/21/24
433 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 12
Total : 44
