Aller au contenu principal
Lenovo X200 Memory Replacement
Ce dont vous avez besoin
  1. Lenovo X200 Memory Replacement, Memory: étape 1, image 1 de 1
    • 1. Unscrew the two phillips #1 size screws that hold the panel to access the two memory modules.
  2. Lenovo X200 Memory Replacement: étape 2, image 1 de 1
    • 2. Remove the panel to access the memory modules.
  3. Lenovo X200 Memory Replacement: étape 3, image 1 de 1
    • Note: If only one DIMM is used on the computer, the card must be installed in SLOT-0 ( a ), not in SLOT-1 ( b ).
    • Remove DIMM by gently spreading the socket connectors up and down as shown in the direction of the arrows and pull the DIMM out.
    • Insert the notched end of the DIMM into the socket.
    • Press the DIMM firmly, and pivot it until it snaps into the place.
    • Make sure that it is firmly fixed in the slot and does not move easily.
4 autres ont terminé cette réparation.
James Finch
Membre depuis le 10/14/17
2 268 Réputation
13 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 1,143
