Introduction
If the speakers produce a buzzing noise or stops working it is important to understand how to replace the speakers.
Ce dont vous avez besoin
Remove eight M2.5 x 8mm Phillips head screws, using a Phillips #0 screwdriver, in the specified locations.
Lift the bottom cover off and set it aside.
Remove the two M2.5x4mm screws using a Phillips #0 screwdriver.
Slide the hard drive out of the casing.
With the laptop's bottom facing up, pull the optical drive release lever back and pull the optical drive out.
Unscrew the three M2x3mm Phillips head screws shown.
At the front edge of the laptop, empty the SD card holder by pressing on the card. This will allow for further disassembly in later steps.
Remove the two M2.5 x 6mm screws using a Phillips #00 screwdriver.
Disconnect the two WiFi antenna cables.
Disconnect the sound connector.
Open the laptop hinge. Tip the laptop onto its side, and use the back end of the screwdriver to push the keyboard out from the optical drive area.
Turn the laptop right side up and pry the keyboard up slowly, until it is clear of the case.
Detach the ribbon cables by opening the specified latches.
Turn the laptop upside down and remove the M2.5x8mm screw with Phillips #0 screwdriver.
Turn the laptop on its side and pry the bottom from the top.
Remove the ribbon cable by opening its respective latch.
Remove the specified cable on top of the motherboard.
Flip the laptop over, and remove the specified cables.
Remove the two M2.5x4mm screws with a Phillips #0 screwdriver
Remove the motherboard with hands.
Outil utilisé dans cette étape :Flathead 3/32" or 2.5 mm Screwdriver$5.49
Remove two M2.0 x 3mm flathead screws on the left side (using the small flathead screwdriver).
Remove two M2.0 x 3mm flathead screws on the right side (using the small flathead screwdriver).
4 autres ont terminé cette réparation.
2 commentaires
Hello Sir,
May I look how the speaker for y410p looks like and what is the model for the speaker? Where can I find that parts? Thanks.
Where can i find the speaker parts?
