Aller au contenu principal
Lenovo Y50 Touch RAM Replacement
Ce dont vous avez besoin
  1. Lenovo Y50 Touch RAM Replacement, RAM: étape 1, image 1 de 2 Lenovo Y50 Touch RAM Replacement, RAM: étape 1, image 2 de 2
    • Place laptop on a flat surface with the back cover facing up.
    • Remove all twelve 6 mm long screws on the back of the laptop using a Phillips #1 screwdriver.
    • Apply a lot of pressure to prevent the screws from stripping.
  2. Lenovo Y50 Touch RAM Replacement: étape 2, image 1 de 2 Lenovo Y50 Touch RAM Replacement: étape 2, image 2 de 2
    • Gently pull off the back cover of the laptop. It should come off easily.
  3. Lenovo Y50 Touch RAM Replacement, Locate the RAM: étape 3, image 1 de 1
    • The RAM should be located at the indicated area inside the laptop.
  4. Lenovo Y50 Touch RAM Replacement, Unclamp the RAM: étape 4, image 1 de 2 Lenovo Y50 Touch RAM Replacement, Unclamp the RAM: étape 4, image 2 de 2
    • Release the clamps securing the RAM by pushing each clamp away from the RAM.
    • Once the clamps are released, the RAM should be facing outward at an angle.
  5. Lenovo Y50 Touch RAM Replacement, Remove the RAM: étape 5, image 1 de 3 Lenovo Y50 Touch RAM Replacement, Remove the RAM: étape 5, image 2 de 3 Lenovo Y50 Touch RAM Replacement, Remove the RAM: étape 5, image 3 de 3
    • Gently unplug the RAM from its port.
    • Do not bend or drop the RAM, as this can affect its function.
    • You can replace up to two RAM sticks for this laptop. Just repeat step 4 for the second RAM port.
    • Pay attention to the arrangement of the pins on the RAM. When replacing the RAM, make sure the pins line up with the pins on the RAM port.
9 autres ont terminé cette réparation.
Andrew Tran
Membre depuis le 01/21/15
820 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 18-1, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 18-1, Maness Winter 2015
CPSU-MANESS-W15S18G1
5 membres
15 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 26
Total : 5,245
