Aller au contenu principal
Lenovo Y50-70 Touch Fan Replacement
Ce dont vous avez besoin
  1. Lenovo Y50-70 Touch Fan Replacement, Back: étape 1, image 1 de 2 Lenovo Y50-70 Touch Fan Replacement, Back: étape 1, image 2 de 2
    • Remove all twelve 6 mm screws from the back of the laptop using a Phillips #1 screwdriver.
    • Apply a lot of pressure to prevent the screws from stripping.
    • Make sure to turn off the computer first!
  2. Lenovo Y50-70 Touch Fan Replacement: étape 2, image 1 de 2 Lenovo Y50-70 Touch Fan Replacement: étape 2, image 2 de 2
    • Gently pull the back cover off the laptop. It should come off easily.
  3. Lenovo Y50-70 Touch Fan Replacement, Fan: étape 3, image 1 de 2 Lenovo Y50-70 Touch Fan Replacement, Fan: étape 3, image 2 de 2
    • Remove the three 3.5 mm screws from the fan with a Philips #1 screwdriver.
  4. Lenovo Y50-70 Touch Fan Replacement: étape 4, image 1 de 3 Lenovo Y50-70 Touch Fan Replacement: étape 4, image 2 de 3 Lenovo Y50-70 Touch Fan Replacement: étape 4, image 3 de 3
    • Pull the wire tabs up one at a time to separate them from the motherboard.
    • Do not pull too hard on the wire tabs. It may damage the connection between the wires and motherboard.
  5. Lenovo Y50-70 Touch Fan Replacement: étape 5, image 1 de 3 Lenovo Y50-70 Touch Fan Replacement: étape 5, image 2 de 3 Lenovo Y50-70 Touch Fan Replacement: étape 5, image 3 de 3
    • Remove the black and white antenna cables from the wireless card.
    • Do not pull too hard on the antenna cables, as it might damage the connection to the wireless card.
  6. Lenovo Y50-70 Touch Fan Replacement: étape 6, image 1 de 3 Lenovo Y50-70 Touch Fan Replacement: étape 6, image 2 de 3 Lenovo Y50-70 Touch Fan Replacement: étape 6, image 3 de 3
    • Lift up the fan slightly.
    • Gather the antenna cables(black and white) and speaker wires (red, black, blue, and white). Carefully move them away from the fan.
  7. Lenovo Y50-70 Touch Fan Replacement: étape 7, image 1 de 2 Lenovo Y50-70 Touch Fan Replacement: étape 7, image 2 de 2
    • Lift the fan off of the laptop.
8 autres ont terminé cette réparation.
Vivian
Membre depuis le 01/21/15
351 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 18-1, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 18-1, Maness Winter 2015
CPSU-MANESS-W15S18G1
5 membres
15 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 19
30 derniers jours : 20
Total : 9,419
