Introduction
This guide will instruct you how to remove a broken Lenovo Y50-70 Touch Fan from your laptop. A touch fan regulates the laptop’s temperature to keep it from overheating, and when it malfunctions it can damage the laptop or make it perform poorly. A fan can get worn out due to frequent use, causing it to malfunction. Dust or debris can also damage the fan. This replacement process requires a careful hand to avoid harming any internal wiring when removing the base of the laptop and the fan itself. To replace the fan, follow these steps in reverse.
Ce dont vous avez besoin
Remove all twelve 6 mm screws from the back of the laptop using a Phillips #1 screwdriver.
8 autres ont terminé cette réparation.
