Aller au contenu principal
Lenovo Y520-15IKBN Display Replacement
Ce dont vous avez besoin
  1. Lenovo Y520-15IKBN Display Replacement, Battery: étape 1, image 1 de 2 Lenovo Y520-15IKBN Display Replacement, Battery: étape 1, image 2 de 2
    • Remove the four 4 mm Phillips #00 screws securing the battery.
  2. Lenovo Y520-15IKBN Display Replacement: étape 2, image 1 de 2 Lenovo Y520-15IKBN Display Replacement: étape 2, image 2 de 2
    • Disconnect the battery connector by pulling the battery cable directly out of its port, toward the battery.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • If necessary, apply force and slowly wiggle the connector out of its socket. It should work its way out slowly.
  3. Lenovo Y520-15IKBN Display Replacement: étape 3, image 1 de 1
    • Lift the battery up and out of the chassis.
  4. Lenovo Y520-15IKBN Display Replacement, Display: étape 4, image 1 de 1
    • Use an opening tool to pry off the display bezel.
  5. Lenovo Y520-15IKBN Display Replacement: étape 5, image 1 de 1
    • Remove the four 4 mm screws with a Phillips #1 screwdriver.
  6. Lenovo Y520-15IKBN Display Replacement: étape 6, image 1 de 1
    • Flip up the gate on the display ribbon cable, and pull it directly out of its port.
    • Remove the display from the computer.
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 41
Total : 1,773
