Aller au contenu principal
Lenovo Yoga 11e Chromebook Battery Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga 11e Chromebook Battery Replacement, Removing the back panel: étape 1, image 1 de 1
    • There will be 7 Philips head screws on the bottom which will need to be removed to gain access to the battery
    • NOTE: You may void your warranty completing this replacement
  2. Lenovo Yoga 11e Chromebook Battery Replacement, Removing the battery screws: étape 2, image 1 de 1
    • There will be 2 other Philips screws under the cover there should also be two arrows pointing at each screw that needs to be removed.
  3. Lenovo Yoga 11e Chromebook Battery Replacement, Removing the battery: étape 3, image 1 de 2 Lenovo Yoga 11e Chromebook Battery Replacement, Removing the battery: étape 3, image 2 de 2
    • Pull up the battery slightly by the tab and pull back
    • Remove the connector from the motherboard and pull the battery up and away from the board
    • Make sure not to pull all the way back as the battery is still connected to the motherboard
    • The computer may not boot when you try to turn it on, plug it into its power supply and it should boot.
Congratulations! You hopefully have successfully completed this guide! To reassemble your device follow the steps backwards.
4 autres ont terminé cette réparation.
Corey Meyer
Membre depuis le 05/01/17
2 292 Réputation
2 tutoriels rédigés
Équipe
Kid fixers Membre de l'équipe Kid fixers
Community
172 membres
229 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 23
Total : 3,143
