Aller au contenu principal
Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement, Back Panel: étape 1, image 1 de 3 Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement, Back Panel: étape 1, image 2 de 3 Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement, Back Panel: étape 1, image 3 de 3
    • Flip the computer over so the bottom is facing up.
    • Remove the ten 6mm screws with a T5 Torx security screwdriver.
  2. Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement: étape 2, image 1 de 1
    • Carefully remove the back panel by gently separating the panel from front to back.
    • Take care not to pull any wires or crack the outer shell.
  3. Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement, Battery: étape 3, image 1 de 3 Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement, Battery: étape 3, image 2 de 3 Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement, Battery: étape 3, image 3 de 3
    • Use the Phillips #000 screwdriver to remove the six 3.3 mm screws around the perimeter of the battery.
    • Use the Phillips #000 screwdriver to remove the single 6.75 mm screw from the center of the battery.
  4. Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement: étape 4, image 1 de 1
    • Gently remove the three pieces of tape securing the Bluetooth/Wi-Fi antenna.
  5. Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement: étape 5, image 1 de 2 Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement: étape 5, image 2 de 2
    • Grip the base of the connector with your fingers or pliers, and gently pull the connector straight back towards you to remove it.
    • If possible, do not to pull the connector out by the wires, as this can damage the connector.
  6. Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement: étape 6, image 1 de 2 Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement: étape 6, image 2 de 2
    • Carefully remove the battery from the laptop.
    • Take care not to pull out the Bluetooth antenna while removing the battery.
  7. Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement, Bluetooth Module: étape 7, image 1 de 1
    • Use the Phillips #000 screwdriver to remove the two 3.3 mm screws.
  8. Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement: étape 8, image 1 de 2 Lenovo Yoga 2 11" 20428 Bluetooth Module Replacement: étape 8, image 2 de 2
    • Gently grab and remove the Bluetooth module.
2 autres ont terminé cette réparation.
Joshua Thomas Tyler
Membre depuis le 03/18/19
687 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 24
Total : 773
