Aller au contenu principal
Lenovo Yoga 2 11" Back Panel Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga 2 11" Back Panel Replacement, Back Panel: étape 1, image 1 de 1
    • With a T5 Torx screwdriver, remove ten 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 11" Back Panel Replacement: étape 2, image 1 de 1
    • Carefully separate back panel from laptop.
3 autres ont terminé cette réparation.
Peyton Leeson
Membre depuis le 10/01/15
939 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 4-3, Maness Fall 2015 Membre de l'équipe Cal Poly, Team 4-3, Maness Fall 2015
CPSU-MANESS-F15S4G3
4 membres
5 tutoriels rédigés
3 commentaires
Thanks for this manual.
Would you have the chance to add a photo of the machine without the cover on? My idea is to be able to see what is easily accessible in order to answer some other users' questions such as this one: Could I replace the hard drive with an SSD
dauffret - Réponse
I believe the "hex screwdriver" is not the correct tool required...I believe it's the Torx screwdriver that would be the correct tool.
David Briggman - Réponse
Not sure if the description has been updated since the 07/30/17 comment but the required tool is a T5 Torx screwdriver that is mentioned in the ‘Tools’ section…and they are not very common!
Ken Swanston - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 19
Total : 4,718
