Introduction
To replace the screen you need to make sure that the hinges are up before you pry off the screen. If not, this will result in a broken screen and will be difficult to replace.
Ce dont vous avez besoin
Locate the small rubber rectangles on either side of the computer, under the screen.
Underneath each of these rectangles is a 3mm screw. Using a Philips 00 screwdriver, take out these screws.
8 autres ont terminé cette réparation.
3 commentaires
Where is the best place to order the replacement screen from?
Tech hanging program how to resolve?
Thank you for this guide.
I found it easy to follow, but the screen sliding up bit got me a bit confused.
However, after carefully reading it again and trying, it makes perfect sense.
Putting the new screen in was a bit fiddly and I couldn't slide it all the way down so the outside edge screws went in.
But, after perseverance, I was able to replace my screen!
