Aller au contenu principal
Introduction
This guide will explain how to safely remove the fan from your Lenovo Yoga 2 13". It will provide a list of the tools needed as well as the easiest way to remove the fan.
  1. With a T5 Torx screwdriver, remove eleven 6.35 mm screws from the back of the laptop.
    • With a T5 Torx screwdriver, remove eleven 6.35 mm screws from the back of the laptop.
  2. Carefully separate back panel from the laptop.
    • Carefully separate back panel from the laptop.
  3. Fix Kits pour Android
    Remplacer l'écran ou la batterie est à portée de kit !
    Acheter maintenant
    Acheter maintenant
  4. Locate the fan near the top of the laptop.
    • Locate the fan near the top of the laptop.
  5. Carefully unscrew three 2.381mm screws using a Phillips head screwdriver.
    • Carefully unscrew three 2.381mm screws using a Phillips head screwdriver.
  6. The fan is attatched to four wires and a white clip. Carefully slide the clip out of the yellow port to completely remove the fan.
    • The fan is attatched to four wires and a white clip. Carefully slide the clip out of the yellow port to completely remove the fan.
13 autre(s) ont terminé cette réparation.
Nichelle
Membre depuis le 11/03/2015
1 421 Réputation
5 tutoriels rédigés
Équipe
Marist, Team 1-2, Laflen Spring 2015 Membre de l'équipe Marist, Team 1-2, Laflen Spring 2015
MARS-LAFLEN-S15S1G2
3 membres
6 tutoriels rédigés
Anyone know where I can buy a replacement fan? I'm having a hard time finding the correct model. I have a first generation Thinkpad Yoga.
Daniel Shen - Réponse
where can i find a new fan for lenovo yoga 2 13
peter trevisan - Réponse
where can i find a new lenovo yoga 2 13?
Han Altae-Tran - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 3
7 derniers jours : 15
30 derniers jours : 88
Total : 11,708
