Aller au contenu principal
Introduction
This guide will explain how to safely remove a specific key from the keyboard of your Lenovo Yoga 2 13". It will provide a list of the tools needed as well as the easiest way to remove the key.
Pièces
Aucune pièce spécifiée.
  1. Using a flat tool, carefully jimmy the selected key until it pops out. Using a flat tool, carefully jimmy the selected key until it pops out.
    • Using a flat tool, carefully jimmy the selected key until it pops out.
  2. Fix Kits pour Android
    Remplacer l'écran ou la batterie est à portée de kit !
    Acheter maintenant
    Acheter maintenant
  3. To insert a new key, simply place and apply pressure until it snaps into place.
    • To insert a new key, simply place and apply pressure until it snaps into place.
Nichelle
Membre depuis le 11/03/2015
1 421 Réputation
5 tutoriels rédigés
Équipe
Marist, Team 1-2, Laflen Spring 2015 Membre de l'équipe Marist, Team 1-2, Laflen Spring 2015
MARS-LAFLEN-S15S1G2
3 membres
6 tutoriels rédigés
this doesn't fix a non-working electric contact, does it?
Simon - Réponse
I came across this page since my Yoga 2 Pro had 2 keys that didn't press down very well. Instead of fully removing the keys, I used a flat tool to pry up the key a little bit, then used compressed air to clean out under the keys. I had to do this a few times from a few different angels, but it finally worked
and the keys feel like normal again.
a.adler55 - Réponse
Does this break the old keys so that you must replace them or is it possible to insert the same ones again?
Johannes Scheller - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 3
7 derniers jours : 20
30 derniers jours : 108
Total : 14,622
