Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Lenovo Yoga 2 13" Screen Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga 2 13" Screen Replacement, Screen: étape 1, image 1 de 2 Lenovo Yoga 2 13" Screen Replacement, Screen: étape 1, image 2 de 2
    • Using an opening pick, remove one small black rectangle piece on each of the hinge corners to locate screws.
    • Using a Phillips head screwdriver, carefully remove one 4.8 mm screw from each corner.
  2. Lenovo Yoga 2 13" Screen Replacement: étape 2, image 1 de 1
    • Using the Jimmy, remove the long centerpiece covering between the hinges.
  3. Lenovo Yoga 2 13" Screen Replacement: étape 3, image 1 de 1
    • Detach the screen from the front panel by sliding the screen up about 2mm. Do not pull too far, as there are still connected wires.
  4. Lenovo Yoga 2 13" Screen Replacement: étape 4, image 1 de 1
    • Locate the gold wire and follow it to two clips. Remove the clips and the clear tape securing the wire.
    • Gently unsnap the wire from the hooks along the perimeter, and remove any tape along the wire.
  5. Lenovo Yoga 2 13" Screen Replacement: étape 5, image 1 de 2 Lenovo Yoga 2 13" Screen Replacement: étape 5, image 2 de 2
    • Completely separate the screen from the laptop.
    • During reassembly, remember to set the screen about 2 mm beyond the lid top edge. Then, slide down to engage the hinges.
11 autres ont terminé cette réparation.
Nichelle
Membre depuis le 03/11/15
1 568 Réputation
5 tutoriels rédigés
Équipe
Marist, Team 1-2, Laflen Spring 2015 Membre de l'équipe Marist, Team 1-2, Laflen Spring 2015
MARS-LAFLEN-S15S1G2
3 membres
7 tutoriels rédigés
3 commentaires de tutoriel
Hi Nichelle,
thanks for your guide. Step 1 and 2 - no problem. But how actually did you do step 3? I can't detach the screen, I can just lift it a few millimeters at the corners or at the side, totally hard..
edit: Ok got it: slide the touch-lcd up a bit :)
Simon - Réponse Partager
Hey Nichelle, do you have any recommended vendors for both the screen and the digitizer? Thanks!
Emmanuel Duarte - Réponse Partager
I used laptopscreen.com.
ken - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 39
Total : 16,794
