Aller au contenu principal
Lenovo Yoga 2 Pro Trackpad Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga 2 Pro Trackpad Replacement, Battery: étape 1, image 1 de 1
    • Please ensure that the laptop is turned off before beginning.
    • Using a Phillips #00 screwdriver, remove the eleven 1/4" screws from the back of the laptop.
  2. Lenovo Yoga 2 Pro Trackpad Replacement: étape 2, image 1 de 1
    • Gently unclip and lift off the back cover.
  3. Lenovo Yoga 2 Pro Trackpad Replacement: étape 3, image 1 de 1
    • Using a Phillips #00 Screwdriver, remove the five 5/16" screws surrounding the battery.
  4. Lenovo Yoga 2 Pro Trackpad Replacement: étape 4, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
  5. Lenovo Yoga 2 Pro Trackpad Replacement: étape 5, image 1 de 2 Lenovo Yoga 2 Pro Trackpad Replacement: étape 5, image 2 de 2
    • Remove the battery from the computer.
  6. Lenovo Yoga 2 Pro Trackpad Replacement, Trackpad: étape 6, image 1 de 1
    • Using a Phillips #00 screwdriver, remove the eight 1/8" screws surrounding the trackpad.
  7. Lenovo Yoga 2 Pro Trackpad Replacement: étape 7, image 1 de 1
    J'achète
    • Using a sharp tool such as tweezers, lift up the black cover that is on top of the ribbon cable.
  8. Lenovo Yoga 2 Pro Trackpad Replacement: étape 8, image 1 de 1
    • With tweezers, gently slide the ribbon cable out from under the connector.
  9. Lenovo Yoga 2 Pro Trackpad Replacement: étape 9, image 1 de 2 Lenovo Yoga 2 Pro Trackpad Replacement: étape 9, image 2 de 2
    • Lift the trackpad out of the computer.
6 autres ont terminé cette réparation.
Thomas Simko
Membre depuis le 10/01/15
2 511 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 12-14, Maness Fall 2015 Membre de l'équipe Cal Poly, Team 12-14, Maness Fall 2015
CPSU-MANESS-F15S12G14
5 membres
12 tutoriels rédigés
3 commentaires
Where can I buy this trackpad? Mine is done.
Jorge Suarez - Réponse
Same here. Where can I buy the part? I cannot even find a part number.
iwaniec - Réponse
I got a lot of different options on ebay but cannot rely on them. I think we could order it from IBM FRU parts but only by email or phone at:
https://www-304.ibm.com/shop/americas/co...
FRU: 73040855
Will try tomorrow
LUIS GARZA - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 23
Total : 9,415
