Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Lenovo Yoga 3 14 Speaker Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga 3 14 Speaker Replacement, Back Case: étape 1, image 1 de 1
    • Remove the eleven 6mm T5 Torx screws from the back case.
  2. Lenovo Yoga 3 14 Speaker Replacement: étape 2, image 1 de 3 Lenovo Yoga 3 14 Speaker Replacement: étape 2, image 2 de 3 Lenovo Yoga 3 14 Speaker Replacement: étape 2, image 3 de 3
    • Insert the plastic opening tool into the long side of the case backing and slide it the entire length of the laptop.
    • Gently lift the backing off the laptop.
  3. Lenovo Yoga 3 14 Speaker Replacement, Battery: étape 3, image 1 de 1
    • Remove the four 3mm PH#0 screws surrounding the battery.
  4. Lenovo Yoga 3 14 Speaker Replacement: étape 4, image 1 de 3 Lenovo Yoga 3 14 Speaker Replacement: étape 4, image 2 de 3 Lenovo Yoga 3 14 Speaker Replacement: étape 4, image 3 de 3
    • Gently lift the battery and use the plastic opening tool to remove the battery's connection to the laptop.
  5. Lenovo Yoga 3 14 Speaker Replacement, Speaker: étape 5, image 1 de 1
    Outil utilisé dans cette étape :
    • Using a pair of tweezers, dissconnect the speakers on the left side of the laptop.
  6. Lenovo Yoga 3 14 Speaker Replacement: étape 6, image 1 de 2 Lenovo Yoga 3 14 Speaker Replacement: étape 6, image 2 de 2
    • Flip up the black retaining flap on the ZIF connector.
    • Using tweezers, gently disconnect the blue strip that connects the touch pad to the motherboard.
  7. Lenovo Yoga 3 14 Speaker Replacement: étape 7, image 1 de 2 Lenovo Yoga 3 14 Speaker Replacement: étape 7, image 2 de 2
    • Use tweezers to gently pull off tape that is holding down wires that are connecting the two speakers together.
  8. Lenovo Yoga 3 14 Speaker Replacement: étape 8, image 1 de 2 Lenovo Yoga 3 14 Speaker Replacement: étape 8, image 2 de 2
    • Both speakers are held in place by plastic pegs. Gently lift the speakers off the casing to remove them.
  9. Lenovo Yoga 3 14 Speaker Replacement: étape 9, image 1 de 2 Lenovo Yoga 3 14 Speaker Replacement: étape 9, image 2 de 2
    • Simply grip the speaker wires and lift away from laptop to remove.
Matthew Victores
Membre depuis le 09/28/16
602 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 3-2, Passmore Fall 2016 Membre de l'équipe USF Tampa, Team 3-2, Passmore Fall 2016
USFT-PASSMORE-F16S3G2
4 membres
7 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 1,395
