Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Lenovo Yoga 3 Pro Speakers Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga 3 Pro Speakers Replacement, Battery: étape 1, image 1 de 1
    • Before opening your laptop, make sure it is powered off.
    • Remove the ten 3.3 mm screws from the base cover using a T5 Torx screwdriver.
  2. Lenovo Yoga 3 Pro Speakers Replacement: étape 2, image 1 de 1
    • Slide the plastic opening tool between the base cover and the frame to pry open the computer.
    • Slowly go around the entire perimeter of the computer until all edges are loose.
    • Make sure the plastic opening tool doesn't go too far into the device.
  3. Lenovo Yoga 3 Pro Speakers Replacement: étape 3, image 1 de 1
    • Remove the panel and place it in a safe location.
  4. Lenovo Yoga 3 Pro Speakers Replacement: étape 4, image 1 de 1
    • Remove the six 3.5 mm screws surrounding the battery using a Phillips 00 screwdriver.
  5. Lenovo Yoga 3 Pro Speakers Replacement: étape 5, image 1 de 1
    Outil utilisé dans cette étape :
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
  6. Lenovo Yoga 3 Pro Speakers Replacement: étape 6, image 1 de 1
    • Carefully lift and remove the battery.
  7. Lenovo Yoga 3 Pro Speakers Replacement, Speakers: étape 7, image 1 de 1
    • Remove the four 4 mm screws using the Phillips 00 screwdriver.
  8. Lenovo Yoga 3 Pro Speakers Replacement: étape 8, image 1 de 2 Lenovo Yoga 3 Pro Speakers Replacement: étape 8, image 2 de 2
    • Using the plastic opening tool, flip open tab as shown.
  9. Lenovo Yoga 3 Pro Speakers Replacement: étape 9, image 1 de 3 Lenovo Yoga 3 Pro Speakers Replacement: étape 9, image 2 de 3 Lenovo Yoga 3 Pro Speakers Replacement: étape 9, image 3 de 3
    • Remove the adhesive tape.
    • Flip open the ribbon connecting tab.
    • Carefully lift the ribbon connector from its adhesive.
  10. Lenovo Yoga 3 Pro Speakers Replacement: étape 10, image 1 de 2 Lenovo Yoga 3 Pro Speakers Replacement: étape 10, image 2 de 2
    • Remove the speaker and set it on the side.
    • Use the plastic opening tool to remove the cables.
    • Be careful of other cables.
  11. Lenovo Yoga 3 Pro Speakers Replacement: étape 11, image 1 de 2 Lenovo Yoga 3 Pro Speakers Replacement: étape 11, image 2 de 2
    • Removing the other speaker by unwinding cables.
    • Lift both speakers carefully.
2 autres ont terminé cette réparation.
Caroline Seifert
Membre depuis le 10/01/15
550 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 12-17, Maness Fall 2015 Membre de l'équipe Cal Poly, Team 12-17, Maness Fall 2015
CPSU-MANESS-F15S12G17
4 membres
15 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 16
30 derniers jours : 65
Total : 3,199
