Aller au contenu principal
Lenovo Yoga 700-11ISK Touchpad Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga 700-11ISK Touchpad Replacement, Back Panel: étape 1, image 1 de 2 Lenovo Yoga 700-11ISK Touchpad Replacement, Back Panel: étape 1, image 2 de 2
    • Flip your device so that the bottom panel is facing up.
    • Remove the eleven 5mm Torx T5 screws from the back panel.
  2. Lenovo Yoga 700-11ISK Touchpad Replacement: étape 2, image 1 de 1
    • Use a spudger to unclip clips on the front and near the USB ports on each side
    • Lift the back panel off
  3. Lenovo Yoga 700-11ISK Touchpad Replacement, Battery: étape 3, image 1 de 1
    • Remove the two 3mm Phillips #1 screws holding the battery to the laptop chassis.
    • Disconnect the battery from the IO board by holding the connector by the sides and gently pulling the connector out.
  4. Lenovo Yoga 700-11ISK Touchpad Replacement: étape 4, image 1 de 1
    • Carefully remove the battery from the laptop.
    • Make sure that all wires still connected to the laptop are out of the way and not pulled out with the battery.
  5. Lenovo Yoga 700-11ISK Touchpad Replacement, Touchpad: étape 5, image 1 de 3 Lenovo Yoga 700-11ISK Touchpad Replacement, Touchpad: étape 5, image 2 de 3 Lenovo Yoga 700-11ISK Touchpad Replacement, Touchpad: étape 5, image 3 de 3
    • Remove the four 4mm Phillips #1 screws holding the touchpad onto the laptop.
    • Use a spudger to lift up the two black tabs on the ZIF connectors and then pull the cable out by the blue tab.
    • The cable should slide in and out effortlessly. If there is resistance when pulling the cable, double check the black tabs.
  6. Lenovo Yoga 700-11ISK Touchpad Replacement: étape 6, image 1 de 1
    • Slightly separate the two halves of the laptop with one hand and slide the touchpad out from the laptop with the other.
    • There may be silver tape holding the touchpad to the laptop. You do not need to replace the tape when reassembling the device.
2 autres ont terminé cette réparation.
Sean Wong
Membre depuis le 10/06/16
859 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 15-6, Livingston Fall 2016 Membre de l'équipe Cal Poly, Team 15-6, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G6
4 membres
7 tutoriels rédigés
Un commentaire
The “Tools Required” section says “Torx T7” but Step 1 lists, and (more importantly) the actual device has Torx T5 screws.
Step 5 suggests using a spudger, so perhaps that should be listed too.
alan - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 13
Total : 2,174
