Aller au contenu principal
Lenovo Yoga 710-11ISK Hinge Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga 710-11ISK Hinge Replacement, Hinge: étape 1, image 1 de 1
    • Remove the eleven screws that secure the bottom panel using a T5 Torx screwdriver.
  2. Lenovo Yoga 710-11ISK Hinge Replacement: étape 2, image 1 de 1
    • Insert an opening tool between the bottom panel and chassis, then pry around the entire perimeter until the five clips detach, releasing the bottom panel.
  3. Lenovo Yoga 710-11ISK Hinge Replacement: étape 3, image 1 de 1
    • Use a Phillips #000 screwdriver to remove the ten black screws on the two hinge brackets.
  4. Lenovo Yoga 710-11ISK Hinge Replacement: étape 4, image 1 de 3 Lenovo Yoga 710-11ISK Hinge Replacement: étape 4, image 2 de 3 Lenovo Yoga 710-11ISK Hinge Replacement: étape 4, image 3 de 3
    • Wedge an opening tool between the display and display housing, then slide the opening tool around the perimeter of the display while gently prying until the display releases.
    • Remove the screw covers located near the hinges on the display side using an opening tool.
    • Remove the cover panel between the screw covers using an opening tool.
  5. Lenovo Yoga 710-11ISK Hinge Replacement: étape 5, image 1 de 1
    • Remove the screws securing the hinge brackets with a Phillips #000 screwdriver.
    • Remove the plastic cover that holds the wires in place.
  6. Lenovo Yoga 710-11ISK Hinge Replacement: étape 6, image 1 de 3 Lenovo Yoga 710-11ISK Hinge Replacement: étape 6, image 2 de 3 Lenovo Yoga 710-11ISK Hinge Replacement: étape 6, image 3 de 3
    • Disconnect the black and white wires from the sides of the display.
    • Disconnect the orange ribbon cable.
    • Remove the tape, covers, and stickers that hold in the components.
  7. Lenovo Yoga 710-11ISK Hinge Replacement: étape 7, image 1 de 2 Lenovo Yoga 710-11ISK Hinge Replacement: étape 7, image 2 de 2
    • Soldering/desoldering presents potential for device damage and burns. Always solder/desolder in a well-ventilated environment.
    • Use a soldering iron to disconnect the ends of both wires that are embedded into the display.
    • Remove the hinges and their components from the computer.
Jarrett Stoll
Membre depuis le 02/10/22
385 Réputation
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 27
Total : 919
