Aller au contenu principal
Lenovo Yoga 710-11ISK Trackpad Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga 710-11ISK Trackpad Replacement, Battery: étape 1, image 1 de 1
    • Flip the device having the bottom panel facing you.
    • Remove the eleven 5mm Torx T5 screws from the back panel.
  2. Lenovo Yoga 710-11ISK Trackpad Replacement, Removing back cover: étape 2, image 1 de 1
    • Remove the back panel carefully.
    • To remove the back cover, there are 5 plastic snap hooks that must be dislodged with a spudger or plastic pick tool.
    • Lay the device upside down with hinges away from you. Tilt it at 45 degree angle, leaving hinges down and open the screen slightly. Apply a little pressure on one corner to see where it separates. Then work from side to side to separate the back case from the top case. The back case is a shell with no components in it.
  3. Lenovo Yoga 710-11ISK Trackpad Replacement: étape 3, image 1 de 2 Lenovo Yoga 710-11ISK Trackpad Replacement: étape 3, image 2 de 2
    • Remove the two 3mm Phillips #1 screws that are holding the battery to the device.
    • Hold the bundled cable connector on each side and carefully pull the connector to release it from the motherboard.
  4. Lenovo Yoga 710-11ISK Trackpad Replacement: étape 4, image 1 de 1
    • Remove the battery carefully from the device by lifting up the edge nearest you and then gently pull toward you to disconnect the power wires.
  5. Lenovo Yoga 710-11ISK Trackpad Replacement, Trackpad: étape 5, image 1 de 1
    • Using a Phillips #00 screwdriver, remove the three 3mm screws located at the top of the trackpad.
  6. Lenovo Yoga 710-11ISK Trackpad Replacement: étape 6, image 1 de 1
    • Remove the trackpad from the device.
Richard
Membre depuis le 02/18/21
241 Réputation
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 1
Total : 120
