Aller au contenu principal
Lenovo Yoga 710-14IKB Headphone Jack Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga 710-14IKB Headphone Jack Replacement, Back Cover: étape 1, image 1 de 1
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB Headphone Jack Replacement: étape 2, image 1 de 3 Lenovo Yoga 710-14IKB Headphone Jack Replacement: étape 2, image 2 de 3 Lenovo Yoga 710-14IKB Headphone Jack Replacement: étape 2, image 3 de 3
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB Headphone Jack Replacement, Battery: étape 3, image 1 de 2 Lenovo Yoga 710-14IKB Headphone Jack Replacement, Battery: étape 3, image 2 de 2
    • Use a Phillips #00 screwdriver to remove the four 3 mm screws holding the battery in place.
    • Be careful not to cross-thread the screws. Also, don't let the screws fall down into the laptop case.
  4. Lenovo Yoga 710-14IKB Headphone Jack Replacement: étape 4, image 1 de 2 Lenovo Yoga 710-14IKB Headphone Jack Replacement: étape 4, image 2 de 2
    • Use your fingers or an opening tool to slide the battery connector out of its motherboard socket.
  5. Lenovo Yoga 710-14IKB Headphone Jack Replacement: étape 5, image 1 de 1
    • Remove the battery.
  6. Lenovo Yoga 710-14IKB Headphone Jack Replacement, Headphone Jack: étape 6, image 1 de 1
    • Remove the two 3mm screws from the headphone jack using a PH00 screwdriver.
    • Make sure not to strip the screws as they can sometimes be hard to remove.
  7. Lenovo Yoga 710-14IKB Headphone Jack Replacement: étape 7, image 1 de 1
    • Pop the black bar on the tip of the wire connected to the headphone jack circuitboard.
    • Disconnect the wire.
    • Be careful not to pull or yank the cable.
  8. Lenovo Yoga 710-14IKB Headphone Jack Replacement: étape 8, image 1 de 2 Lenovo Yoga 710-14IKB Headphone Jack Replacement: étape 8, image 2 de 2
    • Remove the headphone jack circuitboard.
Evan Cruzen
Membre depuis le 11/01/18
253 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S5-G8, Gulbrandsen Fall 2018 Membre de l'équipe UMass Dartmouth, Team S5-G8, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G8
3 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 10
Total : 611
