Aller au contenu principal
Lenovo Yoga 710-14IKB SSD Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga 710-14IKB SSD Replacement, Back Cover: étape 1, image 1 de 1
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB SSD Replacement: étape 2, image 1 de 3 Lenovo Yoga 710-14IKB SSD Replacement: étape 2, image 2 de 3 Lenovo Yoga 710-14IKB SSD Replacement: étape 2, image 3 de 3
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB SSD Replacement, SSD: étape 3, image 1 de 2 Lenovo Yoga 710-14IKB SSD Replacement, SSD: étape 3, image 2 de 2
    • Use a Phillips #00 screwdriver to remove the 3mm screw on the SSD.
  4. Lenovo Yoga 710-14IKB SSD Replacement: étape 4, image 1 de 2 Lenovo Yoga 710-14IKB SSD Replacement: étape 4, image 2 de 2
    • Use your fingers to lift up the SSD and pull away from the socket removing it from the laptop.
7 autres ont terminé cette réparation.
Grant Doerksen
Membre depuis le 04/17/17
1 005 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team S14-G5, Banghart Spring 2017 Membre de l'équipe Cal Poly, Team S14-G5, Banghart Spring 2017
CPSU-BANGHART-S17S14G5
4 membres
27 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 23
30 derniers jours : 103
Total : 11,414
