Aller au contenu principal
Lenovo Yoga 710-15IKB Solid State Drive Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga 710-15IKB Solid State Drive Replacement, Battery: étape 1, image 1 de 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the ten 3.3 mm T5 screws from the base cover.
    • The screws aren't all the same length. Be sure to keep the screws sorted as you work.
  2. Lenovo Yoga 710-15IKB Solid State Drive Replacement: étape 2, image 1 de 1
    • Slide an opening tool between the base and back cover and work your way around the entire device to release the back cover.
  3. Lenovo Yoga 710-15IKB Solid State Drive Replacement: étape 3, image 1 de 1
    • Lift and remove the back cover.
  4. Lenovo Yoga 710-15IKB Solid State Drive Replacement: étape 4, image 1 de 1
    • Remove the four 3.5 mm screws around the battery using a Phillips #1 screwdriver.
  5. Lenovo Yoga 710-15IKB Solid State Drive Replacement: étape 5, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Disconnect the battery by pulling its cable away from the hinge with a pair of tweezers or your fingers.
  6. Lenovo Yoga 710-15IKB Solid State Drive Replacement: étape 6, image 1 de 1
    • Gently lift and remove the battery.
  7. Lenovo Yoga 710-15IKB Solid State Drive Replacement, Solid State Drive: étape 7, image 1 de 1
    • Remove the one JIS 1 screw holding the solid state drive in place.
  8. Lenovo Yoga 710-15IKB Solid State Drive Replacement: étape 8, image 1 de 1
    • Gently pull the solid state drive out and up to remove it from the connector.
3 autres ont terminé cette réparation.
Andrew Keenan
Membre depuis le 11/30/17
173 Réputation
1 tutoriel rédigé
Équipe
University of Maine, Team S1-G5, Diaz Fall 2017 Membre de l'équipe University of Maine, Team S1-G5, Diaz Fall 2017
UMAINE-DIAZ-F17S1G5
4 membres
10 tutoriels rédigés
Un commentaire
No need to remove battery. No need for tweezers.
Shane Whittet - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 36
Total : 7,063
