Aller au contenu principal
Lenovo Yoga 710-15ISK Motherboard Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga 710-15ISK Motherboard Replacement, Back Cover: étape 1, image 1 de 2 Lenovo Yoga 710-15ISK Motherboard Replacement, Back Cover: étape 1, image 2 de 2
    • Flip your laptop over so the bottom is facing upwards.
    • Remove ten 2 mm screws securing the back cover to the laptop using a Phillips #0 screwdriver.
  2. Lenovo Yoga 710-15ISK Motherboard Replacement: étape 2, image 1 de 1
    • Pry the back cover off of the laptop with your fingers.
  3. Lenovo Yoga 710-15ISK Motherboard Replacement, Battery: étape 3, image 1 de 2 Lenovo Yoga 710-15ISK Motherboard Replacement, Battery: étape 3, image 2 de 2
    • Remove the four 2 mm screws from the battery using a Phillips #0 screwdriver.
  4. Lenovo Yoga 710-15ISK Motherboard Replacement: étape 4, image 1 de 1
    • Remove the connector between the battery and the motherboard by gently pulling the black plastic-coated part of the wires.
  5. Lenovo Yoga 710-15ISK Motherboard Replacement: étape 5, image 1 de 1
    • Remove the battery from the laptop.
  6. Lenovo Yoga 710-15ISK Motherboard Replacement, Fans: étape 6, image 1 de 1
    • Remove the four 1.5 mm screws from the fans with a Phillips #00 screwdriver.
  7. Lenovo Yoga 710-15ISK Motherboard Replacement: étape 7, image 1 de 1
    • Unplug the wire connecting the fan to the motherboard by gently pulling the white head from the port.
  8. Lenovo Yoga 710-15ISK Motherboard Replacement: étape 8, image 1 de 2 Lenovo Yoga 710-15ISK Motherboard Replacement: étape 8, image 2 de 2
    • Lift both fans to remove them from the laptop.
  9. Lenovo Yoga 710-15ISK Motherboard Replacement, SSD: étape 9, image 1 de 1
    • Remove the sticker from the SSD to gain access to the screw underneath.
  10. Lenovo Yoga 710-15ISK Motherboard Replacement: étape 10, image 1 de 2 Lenovo Yoga 710-15ISK Motherboard Replacement: étape 10, image 2 de 2
    • Remove the screw holding the SSD in place using a Phillips #0 screwdriver.
    • Gently pull on the plastic clip next to the screw until the stick is freed and bounces up.
  11. Lenovo Yoga 710-15ISK Motherboard Replacement: étape 11, image 1 de 1
    • Slide the SSD out of the laptop.
  12. Lenovo Yoga 710-15ISK Motherboard Replacement, Motherboard: étape 12, image 1 de 1
    • Remove seven 2 mm screws from the motherboard using a Phillips #0 screwdriver.
  13. Lenovo Yoga 710-15ISK Motherboard Replacement: étape 13, image 1 de 3 Lenovo Yoga 710-15ISK Motherboard Replacement: étape 13, image 2 de 3 Lenovo Yoga 710-15ISK Motherboard Replacement: étape 13, image 3 de 3
    • Unplug four cables attached to the motherboard.
    • For the flat ribbon wires, lift the black tabs holding them in place before removing them.
  14. Lenovo Yoga 710-15ISK Motherboard Replacement: étape 14, image 1 de 1
    • Carefully lift out the motherboard to remove it from the laptop.
Annette Limoges
Membre depuis le 10/25/21
181 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 Membre de l'équipe UMass Dartmouth, Team 7-1, Sinclaire Spring 2022
UMASSD-SINCLAIRE-S22S7G1
5 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 249
