Introduction
This guide will show you how to replace the speakers.
Start by flipping the device over so that you see the screws.
  • Start by flipping the device over so that you see the screws.
  • Remove 7 Torx T5 short screws.
  • Remove 3 Torx T5 long screws.
Ajouter un commentaire
  • starting from the USB port use your opening tool to gently pry up the case.
    • Make sure you are prying on the cover itself, not the metal shield around the USB port.
  • Pry along the laptop in the orders the arrows show.
    • Do NOT pry along the top side, or you risk damaging the casing. Stay with the arrows.
  • Lift the case from the bottom side. NOT the side with the hinges.
    • When you feel resistance, do NOT keep lifting or you will damage the housing.
  • Once you feel resistance, gently pull the case towards you. (away from the hinges.)
  • Remove the case.
  • This is the battery. For guides that are for other parts, the battery is removed for the reason of it being a pain to connect or disconnect while screwed in.
    • Be careful not to short anything on the motherboard, as the battery cannot be disconnected before removal.
  • Remove 4 J1 Philips screws.
  • Remove 1 J1 philips screw
    • Do not mix these screws up, as if you put the longer screw where the shorter screw belongs, you will damage the shield around the keyboard.
  • slightly lift the battery using your plastic opening tool.
    • Do not lift the battery out all the way, as it is still connected to the motherboard.
    • Do NOT puncture or deform the battery or it may catch fire or even explode.
  • Pull the battery towards you until the wire is accessible.
  • gently tug and wiggle on the wire until it pops out.
  • Remove the battery.
  • Disconnect the speakers.
  • Remove the left speaker.
  • Remove the Adhesive.
    • Use this pull tab to remove it.
  • Remove the right speaker,
Aiden Baker
Membre depuis le 19/09/2015
9 626 Réputation
29 tutoriels rédigés
Équipe
Cooperators Membre de l'équipe Cooperators
Community
14 membres
76 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 34
Total : 251
