Aller au contenu principal
Lenovo Yoga 720-12IKB Motherboard Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga 720-12IKB Motherboard Replacement, Battery: étape 1, image 1 de 1
    • Unscrew and remove the four 5.5 mm Phillips #00 screws on the back panel.
  2. Lenovo Yoga 720-12IKB Motherboard Replacement: étape 2, image 1 de 1
    • Pull down on the cover to remove it and you will see the battery after removing the cover.
  3. Lenovo Yoga 720-12IKB Motherboard Replacement: étape 3, image 1 de 2 Lenovo Yoga 720-12IKB Motherboard Replacement: étape 3, image 2 de 2
    • Unscrew and remove the 4.0 mm Phillips #00 screws on the battery to remove it from the motherboard.
  4. Lenovo Yoga 720-12IKB Motherboard Replacement: étape 4, image 1 de 2 Lenovo Yoga 720-12IKB Motherboard Replacement: étape 4, image 2 de 2
    • Remove the battery wires from the socket on the motherboard above the battery.
  5. Lenovo Yoga 720-12IKB Motherboard Replacement: étape 5, image 1 de 1
    • Finally remove the battery from the case.
  6. Lenovo Yoga 720-12IKB Motherboard Replacement, Motherboard: étape 6, image 1 de 1
    • The motherboard is located above the battery.
  7. Lenovo Yoga 720-12IKB Motherboard Replacement: étape 7, image 1 de 1
    • Unscrew and remove the 2.0 mm Phillips #00 screws.
  8. Lenovo Yoga 720-12IKB Motherboard Replacement: étape 8, image 1 de 2 Lenovo Yoga 720-12IKB Motherboard Replacement: étape 8, image 2 de 2
    • Disconnect the connectors by lifting up the clip and pulling them out.
  9. Lenovo Yoga 720-12IKB Motherboard Replacement: étape 9, image 1 de 1
    • Remove the 4.0 mm Phillips #00 screws from the fan.
    • Remove the 4.0 mm Phillips #00 screws from the heatsink.
  10. Lenovo Yoga 720-12IKB Motherboard Replacement: étape 10, image 1 de 2 Lenovo Yoga 720-12IKB Motherboard Replacement: étape 10, image 2 de 2
    • Remove the 5.5 mm Phillips #00 screws from the hinge.
    • Remove the 4.0 mm Phillips #00 screws froom the hinge.
    • Open the laptop a little to lift the hinge.
  11. Lenovo Yoga 720-12IKB Motherboard Replacement: étape 11, image 1 de 1
    • Remove the motherboard after all screws are out and connectors are disconnected.
Alex Escobar
Membre depuis le 02/10/22
778 Réputation
6 tutoriels rédigés
Équipe
Gateway, Team 1-4, Pee Spring 2022 Membre de l'équipe Gateway, Team 1-4, Pee Spring 2022
GCC-PEE-S22S1G4
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 16
Total : 380
