Aller au contenu principal
Lenovo Yoga 730-13IKB Storage Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga 730-13IKB Storage Replacement, Back Case: étape 1, image 1 de 3 Lenovo Yoga 730-13IKB Storage Replacement, Back Case: étape 1, image 2 de 3 Lenovo Yoga 730-13IKB Storage Replacement, Back Case: étape 1, image 3 de 3
    • Power off the laptop and place it facedown on a non-scratching surface.
    • Remove the nine T5 screws fastening the back case.
  2. Lenovo Yoga 730-13IKB Storage Replacement: étape 2, image 1 de 3 Lenovo Yoga 730-13IKB Storage Replacement: étape 2, image 2 de 3 Lenovo Yoga 730-13IKB Storage Replacement: étape 2, image 3 de 3
    • Slide a plastic opening tool underneath the back case near the screen hinges. Gently pry up on either side.
    • Slide the opening tool underneath the back case next to the middle screw hole at either side of the case. Gently pry up.
    • You may hear popping sounds as the tabs securing the case release. This is normal. If the case does not move, try prying at a different angle/position.
  3. Lenovo Yoga 730-13IKB Storage Replacement: étape 3, image 1 de 1
    • Remove the back case by pulling up near the screen hinges and lifting diagonally away from the laptop.
    • Go slowly to avoid breaking any connecting tabs.
  4. Lenovo Yoga 730-13IKB Storage Replacement, Storage: étape 4, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the 4mm screw holding down the storage drive.
  5. Lenovo Yoga 730-13IKB Storage Replacement: étape 5, image 1 de 2 Lenovo Yoga 730-13IKB Storage Replacement: étape 5, image 2 de 2
    • Hold onto the back of the storage drive and slightly lift up.
    • Remove the drive by pulling back at a diagonal angle.
    • To install the storage drive, insert it into the connector at a slight downwards angle. The drive connector is keyed and will only go in one way.
Colin Reay
Membre depuis le 01/23/20
848 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team S1-G1, White Winter 2020 Membre de l'équipe Cal Poly, Team S1-G1, White Winter 2020
CPSU-WHITE-W20S1G1
3 membres
14 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 27
Total : 1,376
