Introduction
Use this guide to replace the touchscreen display on a Lenovo Yoga 730 13-IKB (model numbers starting with “81CT”). The touchscreen display functions as a regular display and also recognizes direct, physical user input.
Many screen-related problems can be remedied with software fixes. Review the Lenovo Yoga 730-13IKB troubleshooting guide if you are experiencing display issues before replacing the touchscreen assembly.
Replacing the touchscreen is an advanced process and is recommended for confident users. Keep any debris or liquids away from the computer while replacing the motherboard because the internal components of the laptop are exposed.
Ce dont vous avez besoin
Use a Phillips #00 screwdriver to remove the eight 2.5mm screws securing the heat sink assembly.
Use a Phillips #00 screwdriver to remove the six 2.5mm screws holding down the touch pad.
Use a Phillips #00 screwdriver to remove the five 3.5mm screws securing the motherboard.
Use a Phillips #00 screwdriver to remove the four 4mm display hinge screws.
