Aller au contenu principal
Lenovo Yoga 910-13IKB Trackpad Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga 910-13IKB Trackpad Replacement, Back Panel: étape 1, image 1 de 2 Lenovo Yoga 910-13IKB Trackpad Replacement, Back Panel: étape 1, image 2 de 2
    • Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel using the T5 Torx Screwdriver.
    • Remove the back panel from the device exposing the components.
  2. Lenovo Yoga 910-13IKB Trackpad Replacement, Battery: étape 2, image 1 de 1
    • Remove the four 3 mm Phillips #0 screws holding the battery in place.
  3. Lenovo Yoga 910-13IKB Trackpad Replacement: étape 3, image 1 de 3 Lenovo Yoga 910-13IKB Trackpad Replacement: étape 3, image 2 de 3 Lenovo Yoga 910-13IKB Trackpad Replacement: étape 3, image 3 de 3
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery. The spudger tool may be needed to lift the flap seal.
    • Pull parallel to the battery, not straight up.
    • Pull evenly on the width of the cable so that no individual wire is overly strained.
    • Lift the battery out.
  4. Lenovo Yoga 910-13IKB Trackpad Replacement, Trackpad: étape 4, image 1 de 3 Lenovo Yoga 910-13IKB Trackpad Replacement, Trackpad: étape 4, image 2 de 3 Lenovo Yoga 910-13IKB Trackpad Replacement, Trackpad: étape 4, image 3 de 3
    • Using the Phillips #0 screwdriver, remove all six screws holding the trackpad to the device.
    • Find the ribbon cable, the black bundle of wires attached to the trackpad, and lift the head of the ribbon cable towards you.
    • Carefully lift up the trackpad and remove it from the device.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 401
