Aller au contenu principal
Lenovo Yoga 910-13IKB Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement, Back Panel: étape 1, image 1 de 2 Lenovo Yoga 910-13IKB Wi-Fi Card Replacement, Back Panel: étape 1, image 2 de 2
    • Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel using the T5 Torx Screwdriver.
    • Remove the back panel from the device exposing the components.
  2. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement, Battery: étape 2, image 1 de 1
    • Remove the four 3 mm Phillips #0 screws holding the battery in place.
  3. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: étape 3, image 1 de 3 Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: étape 3, image 2 de 3 Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: étape 3, image 3 de 3
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery. The spudger tool may be needed to lift the flap seal.
    • Pull parallel to the battery, not straight up.
    • Pull evenly on the width of the cable so that no individual wire is overly strained.
    • Lift the battery out.
  4. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement, Wi-Fi Card: étape 4, image 1 de 1
    • Remove the single 1 mm screw at left of Wi-Fi card with a Phillips #0 screwdriver.
  5. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: étape 5, image 1 de 2 Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: étape 5, image 2 de 2
    • Pull the Wi-Fi card out of the slot on the motherboard.
    • It is still connected to the coaxial cables so don't yank it out or those connections will break.
  6. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: étape 6, image 1 de 3 Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: étape 6, image 2 de 3 Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: étape 6, image 3 de 3
    • Detach the white wire that is connected to the Wi-Fi card by applying gentle pressure.
    • Detach the black wire by applying gentle pressure.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 12
30 derniers jours : 32
Total : 516
