Aller au contenu principal
Lenovo Yoga 920-13IKB Audio Jack Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga 920-13IKB Audio Jack Replacement, Back Cover: étape 1, image 1 de 2 Lenovo Yoga 920-13IKB Audio Jack Replacement, Back Cover: étape 1, image 2 de 2
    • Flip the device over to access the screws on the back cover.
    • Remove the ten 5mm Torx T5 screws on the back cover to loosen the back cover.
  2. Lenovo Yoga 920-13IKB Audio Jack Replacement: étape 2, image 1 de 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: étape 2, image 2 de 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: étape 2, image 3 de 3
    • Slide the iFixit Opening Tool under the back cover to lift it up.
    • Pull up on the cover with your hand to release the tab holding the center of the cover in place.
  3. Lenovo Yoga 920-13IKB Audio Jack Replacement, Motherboard: étape 3, image 1 de 2 Lenovo Yoga 920-13IKB Audio Jack Replacement, Motherboard: étape 3, image 2 de 2
    • Remove the twelve 5mm Phillips #00 screws to loosen the motherboard.
  4. Lenovo Yoga 920-13IKB Audio Jack Replacement: étape 4, image 1 de 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: étape 4, image 2 de 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: étape 4, image 3 de 3
    • Flip up the ten flat connectors holding the motherboard using the iFixit Opening Tool to free the motherboard.
  5. Lenovo Yoga 920-13IKB Audio Jack Replacement: étape 5, image 1 de 2 Lenovo Yoga 920-13IKB Audio Jack Replacement: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Pull out the ribbon cables from the opened connectors using the iFixit Tweezers to free up the motherboard.
  6. Lenovo Yoga 920-13IKB Audio Jack Replacement: étape 6, image 1 de 2 Lenovo Yoga 920-13IKB Audio Jack Replacement: étape 6, image 2 de 2
    • Disconnect the battery by pulling the ribbon wire grouping out of the top of the motherboard.
  7. Lenovo Yoga 920-13IKB Audio Jack Replacement: étape 7, image 1 de 2 Lenovo Yoga 920-13IKB Audio Jack Replacement: étape 7, image 2 de 2
    • Disconnect the red and black wire from the motherboard using the iFixit Tweezers.
  8. Lenovo Yoga 920-13IKB Audio Jack Replacement: étape 8, image 1 de 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: étape 8, image 2 de 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: étape 8, image 3 de 3
    • Lift the motherboard up parallel to the hinge of the device.
    • Gently pull away from the port cutouts of the USB-C and audio jack to remove the motherboard from the device casing.
    • Avoid pulling the motherboard all the way out until the green AC card is disconnected.
  9. Lenovo Yoga 920-13IKB Audio Jack Replacement: étape 9, image 1 de 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: étape 9, image 2 de 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: étape 9, image 3 de 3
    • Disconnect the green AC card plugged into the motherboard by pulling it out with your hands.
  10. Lenovo Yoga 920-13IKB Audio Jack Replacement: étape 10, image 1 de 1
    • Flip the motherboard over to access the back side.
  11. Lenovo Yoga 920-13IKB Audio Jack Replacement: étape 11, image 1 de 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: étape 11, image 2 de 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: étape 11, image 3 de 3
    • Remove four 3mm JIS #00 screws with the screwdriver.
    • Remove one 3mm Phillips #00 screw with the screwdriver.
    • The screws stay attached to the speaker when removed from the motherboard.
  12. Lenovo Yoga 920-13IKB Audio Jack Replacement: étape 12, image 1 de 1
    • Separate the fans from the motherboard to isolate it for replacement.
  13. Lenovo Yoga 920-13IKB Audio Jack Replacement, Audio Jack: étape 13, image 1 de 1
    • Replace the motherboard to replace the audio jack.
Alyssa McCulloch
Membre depuis le 01/24/19
1 906 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team S2-G3, White Winter 2019 Membre de l'équipe Cal Poly, Team S2-G3, White Winter 2019
CPSU-WHITE-W19S2G3
4 membres
29 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 16
Total : 806
