Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Lenovo Yoga C930-13IKB Coolant Fan Replacement
Ce dont vous avez besoin
    1. Lenovo Yoga C930-13IKB Coolant Fan Replacement, Back Cover: étape 1, image 1 de 1
      • Flip the device over so that the underside is facing up.
      • Remove the six 3.5 mm T5 Torx screws.
      Demander à FixBot
      Ajouter un commentaire
    2. Lenovo Yoga C930-13IKB Coolant Fan Replacement: étape 2, image 1 de 2 Lenovo Yoga C930-13IKB Coolant Fan Replacement: étape 2, image 2 de 2
      • Pry off the back cover using the plastic opening tool.
      • Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
      • You may have to run the plastic tool along the edges until you find a small gap to separate the back cover from the laptop.
      • Do not use a metal tool when working with your device.
      Demander à FixBot
    3. Lenovo Yoga C930-13IKB Coolant Fan Replacement: étape 3, image 1 de 2 Lenovo Yoga C930-13IKB Coolant Fan Replacement: étape 3, image 2 de 2
      • Carefully lift the cover off with your hands.
      Demander à FixBot
    1. Lenovo Yoga C930-13IKB Coolant Fan Replacement, Coolant Fans: étape 4, image 1 de 1
      • Remove the four 3 mm Phillips #0 screws from the fan assembly.
      Demander à FixBot
    2. Lenovo Yoga C930-13IKB Coolant Fan Replacement: étape 5, image 1 de 1
      • Remove the four 2 mm Phillips #00 screws from the fans themselves.
      Demander à FixBot
    3. Lenovo Yoga C930-13IKB Coolant Fan Replacement: étape 6, image 1 de 1
      • Unscrew the three 3 mm Phillips #0 screws on the heatsink.
      Demander à FixBot
    4. Lenovo Yoga C930-13IKB Coolant Fan Replacement: étape 7, image 1 de 2 Lenovo Yoga C930-13IKB Coolant Fan Replacement: étape 7, image 2 de 2
      • Use a plastic opening tool to remove the two small, white power cable connectors for each of the two fans.
      Demander à FixBot
    5. Lenovo Yoga C930-13IKB Coolant Fan Replacement: étape 8, image 1 de 1
      • Gently lift the fan assembly out of the laptop.
      • Be sure to clean and reapply thermal paste to the heatsink during reassembly.
      Demander à FixBot
To reassemble your device, follow these instructions in reverse order. Remember to apply fresh thermal paste to the heatsink during reassembly.
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 50
Total : 2,431
