Introduction
This guide includes all the steps, tools, and parts necessary to disassemble the Lenovo Yoga C930-13IKB to access and replace the hinge assembly.
Ce dont vous avez besoin
Flip the device over so that the underside is facing up.
Remove the six 3.5 mm T5 Torx screws.
Unplug the battery from the motherboard by pinching the cables with your fingers and tugging out with force.
Use your fingers to pry up the clear plastic pull-tab for one of the stretch release adhesives.
Grasp the pull-tab and slowly pull away from the battery at a shallow angle. The adhesive strip will stretch to many times its length and slowly release from underneath the battery.
Repeat the procedure for the second strip on the opposite side of the battery.
Remove the battery with your hands.
Outil utilisé dans cette étape :Halberd Spudger$2.99
Using the Halberd Spudger, gently lift the black tab on top of each of the five ZIF connectors for the ribbon cables. Then pull the cables out from the connectors.
Using a halberd spudger, gently lift up the metal bezel that lines the lower edge of the display.
Remove the eight 3 mm screws from the hinge attachments on the back cover using the Phillips #00 screwdriver.
Carefully detach the hinge assembly connectors from the LCD cover to detach it from the back cover.
3 autres ont terminé cette réparation.
