Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Lenovo Yoga C930-13IKB Power Button Board Replacement
Ce dont vous avez besoin
    1. Lenovo Yoga C930-13IKB Power Button Board Replacement, Back Cover: étape 1, image 1 de 1
      • Flip the device over so that the underside is facing up.
      • Remove the six 3.5 mm T5 Torx screws.
      Demander à FixBot
      Ajouter un commentaire
    2. Lenovo Yoga C930-13IKB Power Button Board Replacement: étape 2, image 1 de 2 Lenovo Yoga C930-13IKB Power Button Board Replacement: étape 2, image 2 de 2
      • Pry off the back cover using the plastic opening tool.
      • Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
      • You may have to run the plastic tool along the edges until you find a small gap to separate the back cover from the laptop.
      • Do not use a metal tool when working with your device.
      Demander à FixBot
    3. Lenovo Yoga C930-13IKB Power Button Board Replacement: étape 3, image 1 de 2 Lenovo Yoga C930-13IKB Power Button Board Replacement: étape 3, image 2 de 2
      • Carefully lift the cover off with your hands.
      Demander à FixBot
    1. Lenovo Yoga C930-13IKB Power Button Board Replacement, Battery: étape 4, image 1 de 3 Lenovo Yoga C930-13IKB Power Button Board Replacement, Battery: étape 4, image 2 de 3 Lenovo Yoga C930-13IKB Power Button Board Replacement, Battery: étape 4, image 3 de 3
      • Unplug the battery from the motherboard by pinching the cables with your fingers and tugging out with force.
      • Use the spudger for assistance.
      Demander à FixBot
    2. Lenovo Yoga C930-13IKB Power Button Board Replacement: étape 5, image 1 de 1
      • Unscrew the four 3mm screws with a Phillips screwdriver.
      Demander à FixBot
    3. Lenovo Yoga C930-13IKB Power Button Board Replacement: étape 6, image 1 de 2 Lenovo Yoga C930-13IKB Power Button Board Replacement: étape 6, image 2 de 2
      • The battery is still held in place with two stretch-release adhesive strips, similar to ones found in an iPhone.
      • Use your fingers to pry up the clear plastic pull-tab for one of the stretch release adhesives.
      • Grasp the pull-tab and slowly pull away from the battery at a shallow angle. The adhesive strip will stretch to many times its length and slowly release from underneath the battery.
      • Repeat the procedure for the second strip on the opposite side of the battery.
      • Be careful not to bend the battery. Breaking the battery is dangerous.
      • Remove the battery with your hands.
      Demander à FixBot
    1. Lenovo Yoga C930-13IKB Power Button Board Replacement, SSD: étape 7, image 1 de 1
      • Remove the screw ( 2 mm with a 5 mm head) that connect the SSD to the motherboard using a Phillips #00 screwdriver.
      Demander à FixBot
    2. Lenovo Yoga C930-13IKB Power Button Board Replacement: étape 8, image 1 de 1
      • Pinch the left side of the SSD card.
      • Pull gently to the left, horizontal to the laptop.
      Demander à FixBot
    1. Lenovo Yoga C930-13IKB Power Button Board Replacement, Power Button Board: étape 9, image 1 de 3 Lenovo Yoga C930-13IKB Power Button Board Replacement, Power Button Board: étape 9, image 2 de 3 Lenovo Yoga C930-13IKB Power Button Board Replacement, Power Button Board: étape 9, image 3 de 3
      • Unscrew the two 2mm screws using a Phillips #00 screwdriver.
      • Gently lift out the digital pen spring using the iFixit opening tool.
      Demander à FixBot
    2. Lenovo Yoga C930-13IKB Power Button Board Replacement: étape 10, image 1 de 3 Lenovo Yoga C930-13IKB Power Button Board Replacement: étape 10, image 2 de 3 Lenovo Yoga C930-13IKB Power Button Board Replacement: étape 10, image 3 de 3
      • Remove four 2 mm screws from the digital pen holder using a Phillips #00 screwdriver.
      • Do not remove the pen holder until the attached ribbon cable is uninstalled.
      Demander à FixBot
    3. Lenovo Yoga C930-13IKB Power Button Board Replacement: étape 11, image 1 de 2 Lenovo Yoga C930-13IKB Power Button Board Replacement: étape 11, image 2 de 2
      Outil utilisé dans cette étape :
      • Using the angled ESD tweezers, gently lift the black tab on top of the ZIF connector on the motherboard which connects the power button ribbon cable.
      • Gently pull the cable out from the connector.
      Demander à FixBot
    4. Lenovo Yoga C930-13IKB Power Button Board Replacement: étape 12, image 1 de 2 Lenovo Yoga C930-13IKB Power Button Board Replacement: étape 12, image 2 de 2
      • Carefully lift out the digital pen holder with the attached power button ribbon cable.
      Demander à FixBot
    5. Lenovo Yoga C930-13IKB Power Button Board Replacement: étape 13, image 1 de 3 Lenovo Yoga C930-13IKB Power Button Board Replacement: étape 13, image 2 de 3 Lenovo Yoga C930-13IKB Power Button Board Replacement: étape 13, image 3 de 3
      • Depress the power button, then gently pull and detach it using the angled ESD tweezers.
      Demander à FixBot
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 42
Total : 2,568
