Ce dont vous avez besoin
Open the kickstand by pressing the release button in the center.
Remove the identification sticker with a pair of tweezers to allow access to the two 2mm screws underneath.
With the tablet oriented screen side down and hinge opposite of you, locate the black plastic piece on the top right.
Remove the upper 4mm and lower 3mm screws with a PH00 screwdriver.
At the opposite end of the hinge, locate the silver metal bracket over the wires coming from the end of the hinge. Remove the two 3mm screws with a PH00 screwdriver. Lift the bracket off with your fingers.
Removing the bracket will expose two silver connectors at the ends of the wires coming from the end of the hinge. Use tweezers to carefully lift off the two silver connectors.
Locate the smaller metal wire bracket guiding the wires coming from the end of the hinge. Remove the single black 2mm screw with a PH00 screwdriver. Lift the bracket off with your fingers.
