Aller au contenu principal
Lenovo Yoga Tab 3 8 Kickstand Lock Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga Tab 3 8 Kickstand Lock Replacement, Back Cover: étape 1, image 1 de 3 Lenovo Yoga Tab 3 8 Kickstand Lock Replacement, Back Cover: étape 1, image 2 de 3 Lenovo Yoga Tab 3 8 Kickstand Lock Replacement, Back Cover: étape 1, image 3 de 3
    • Open the kickstand by pressing the release button in the center.
    • Remove the identification sticker with a pair of tweezers to allow access to the two 2mm screws underneath.
  2. Lenovo Yoga Tab 3 8 Kickstand Lock Replacement: étape 2, image 1 de 1
    • Remove the three 2mm screws under the kickstand with a PH00 screwdriver.
    • The third 2mm screw to the right may have an S sticker covering it which you can scrape off.
  3. Lenovo Yoga Tab 3 8 Kickstand Lock Replacement: étape 3, image 1 de 3 Lenovo Yoga Tab 3 8 Kickstand Lock Replacement: étape 3, image 2 de 3 Lenovo Yoga Tab 3 8 Kickstand Lock Replacement: étape 3, image 3 de 3
    • Starting along the edge opposite of the hinge, insert a plastic opening tool between the screen and the backing to begin separating the small clips holding the backing on.
    • Work along the edge and then up the sides, separating the clips with the plastic opening tool.
    • There is adhesive underneath the slot for the SD card so you will need to slowly apply some force to break the adhesive.
    • As the back is separated from the device, be careful to not lose the power button. It may come loose and fall out.
  4. Lenovo Yoga Tab 3 8 Kickstand Lock Replacement, Kickstand Lock: étape 4, image 1 de 1
    • Locate the four 2mm screws that secure the lock and remove them with a PH00 screwdriver.
  5. Lenovo Yoga Tab 3 8 Kickstand Lock Replacement: étape 5, image 1 de 2 Lenovo Yoga Tab 3 8 Kickstand Lock Replacement: étape 5, image 2 de 2
    • Pry the lock up with a metal spudger. There is adhesive holding the mechanism down. Carefully separate it using even pressure.
Nicklaus Krems
Membre depuis le 09/25/17
1 049 Réputation
8 tutoriels rédigés
Équipe
USF Tampa, Team S16-G2, Eyestone Fall 2017 Membre de l'équipe USF Tampa, Team S16-G2, Eyestone Fall 2017
USFT-EYESTONE-F17S16G2
4 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 4
Total : 887
