Introduction
This guide will demonstrate the step by step process on how to replace the motherboard in your Lenovo Z70-80.
Ce dont vous avez besoin
Use your fingers two push both latches away from each other to release the battery.
Pull the battery out.
Remove the two Phillips #0 screws from the bottom panel.
Slide the panel down slightly, and then lift to pull it off.
Remove the single 3mm Phillips #0 screw from the optical drive.
Pull the optical drive out of the side.
Remove the three 6mm Phillips #0 screws from the fan.
Disconnect the fan from the motherboard by pulling up on the plug.
Remove all the 17 7mm Phillips #0 screws.
A sticker covers this screw. Remove this sticker to remove the screw.
Remove the back cover.
3 autres ont terminé cette réparation.
