Introduction
This guide will demonstrate how you can replace the optical drive on your Lenovo Z70-80 laptop.
Ce dont vous avez besoin
Use your fingers two push both latches away from each other to release the battery.
Pull the battery out.
Remove the two Phillips #0 screws from the bottom panel.
Slide the panel down slightly, and then lift to pull it off.
Remove the single 3mm Phillips #0 screw from the optical drive.
Pull the optical drive out of the side.
