Aller au contenu principal
Pièces
Aucune pièce spécifiée.
  1. 3 Phillips screws are located under the battery cover, unscrew them
    • 3 Phillips screws are located under the battery cover, unscrew them
  2. The mouse cover at the bottom should move freely but at the top is hold by 2 brackets In order to remove the mouse cover, you will need to rock left/right the cover and slide it down (from scroll wheel toward the Lenovo logo)
    • The mouse cover at the bottom should move freely but at the top is hold by 2 brackets
    • In order to remove the mouse cover, you will need to rock left/right the cover and slide it down (from scroll wheel toward the Lenovo logo)
  3. Fix Kits pour batteries d'iPhone
    Seulement $29.99
    Buy Now
    Seulement $29.99
    Buy Now
  4. At this point, you have separated the mouse cover At this point, you have separated the mouse cover
    • At this point, you have separated the mouse cover
  5. Use the appropriate tool to remove gently the power connector. Don't use your finger, you might brake the cable
    • Use the appropriate tool to remove gently the power connector. Don't use your finger, you might brake the cable
  6. The micro switch can be replaced by OMRON D2FC-F-7N but you need to trim the solder terminals with a flush wire cutter When you reassemble the mouse, make sure you don't crush the power cable
    • The micro switch can be replaced by OMRON D2FC-F-7N but you need to trim the solder terminals with a flush wire cutter
    • When you reassemble the mouse, make sure you don't crush the power cable
Shinn Chyang Chen
Membre depuis le 14/09/2011
2 212 Réputation
3 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 37
Total : 2,986
