Aller au contenu principal
Les Paul Wireless Guitar Battery Pack Replacement
Ce dont vous avez besoin
  1. Les Paul Wireless Guitar Battery Pack Replacement, Les Paul Wireless Guitar Body Teardown: étape 1, image 1 de 1
    • Remove batteries
  2. Les Paul Wireless Guitar Battery Pack Replacement: étape 2, image 1 de 2 Les Paul Wireless Guitar Battery Pack Replacement: étape 2, image 2 de 2
    • Remove void warranty sticker
    • The sticker is covering a torx screw
  3. Les Paul Wireless Guitar Battery Pack Replacement: étape 3, image 1 de 3 Les Paul Wireless Guitar Battery Pack Replacement: étape 3, image 2 de 3 Les Paul Wireless Guitar Battery Pack Replacement: étape 3, image 3 de 3
    • Unscrew the 11 screws securing the back of the body using a T10 Torx screwdriver. Each screw is 1 cm long.
    • Push level, this will detach the back of the guitar from the front.
    • Carefully remove the back of the body
    • The battery pack cord is attached to both sides of the guitar, be careful not to tear it apart.
    • The neck connector may be stuck to the back so be sure to detach it before fully pulling
  4. Les Paul Wireless Guitar Battery Pack Replacement, Battery Pack: étape 4, image 1 de 2 Les Paul Wireless Guitar Battery Pack Replacement, Battery Pack: étape 4, image 2 de 2
    • Gently move the capacitor around until it breaks off
    Not been playing the guitar for years. Forgotten all about it until one day I decided to have a go again. But discovered I had left the AA batteries inside and it the battery compartment had been swimming in alkali cos of battery corrosion. Saw your post here and decided to have a go at fixing it. Can I know how do you tell that the capacitor is due for replacement and also, can the red wire be directly soldered to the positive end of the battery connector lead?
    limtk55 - Réponse
    I decided to come back and play it again but the only problem is that I forgot that a black and red wire got ripped out from the top side of the battery pack I don't know if this is fixale or not and with my other one it's fine it just won't connect the light flickers and goes off
    Christian Reed - Réponse
  5. Les Paul Wireless Guitar Battery Pack Replacement: étape 5, image 1 de 1
    • Solder on the new capacitor.
    My guitar does not have the capacitor- what’s the uf and v?
    Mikekt - Réponse
    Did you ever find a replacement capacitor?
    Josh -
    it’s a 2200uf 10V Capacitor
    Corban Figueroa - Réponse
3 autres ont terminé cette réparation.
Chris
Membre depuis le 10/18/13
881 Réputation
6 tutoriels rédigés
2 commentaires
What cap is needed?
Martin Samuelsson - Réponse
Mine is: 2200uF 10V
Thijs van Ulden -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 13
30 derniers jours : 89
Total : 12,216
