Introduction
This guide will help you change your engine air filter quickly and easily. Changing the engine air filter in your Lexus IS350/250 is essential for maintaining optimal engine performance and fuel efficiency. Before starting, ensure your car is parked on a flat surface, the engine is cool, and you have the correct replacement filter. Be cautious of sharp edges under the hood and make sure to secure the hood properly to avoid it falling.
Additional Information:
- Caution: Make sure the engine is cool before starting this procedure to avoid burns.
Ce dont vous avez besoin
Pull the hood latch located under the dashboard on the driver’s side to release the hood.
Raise the car's hood until the hood struts engage and hold it in the open position.
You have successfully changed your engine air filter for your Lexus IS350/250!
