Aller au contenu principal
Lezyne Micro Drive Battery Replacement
Ce dont vous avez besoin
  1. Lezyne Micro Drive Battery Replacement, Battery: étape 1, image 1 de 1
    • Mount the light in between a 11mm socket and 22 socket like so in a vice.
  2. Lezyne Micro Drive Battery Replacement: étape 2, image 1 de 1
    • Slowly clamp, the clear light cover will push in. There is quite a lot of resistance.
  3. Lezyne Micro Drive Battery Replacement: étape 3, image 1 de 1
    • Keep on going until the resistance fades. The light cover will be depressed as shown. and the electronics will just fall out.
  4. Lezyne Micro Drive Battery Replacement: étape 4, image 1 de 3 Lezyne Micro Drive Battery Replacement: étape 4, image 2 de 3 Lezyne Micro Drive Battery Replacement: étape 4, image 3 de 3
    • You can see where the electronics slides into.
    • You can see how it is held in with friction from the raised plastic bevel. If you wish to make it easier to disassemble, file the friction bevel down. Don't file down the keying semi circular bevel.
    • The last picture shows the plastic filed down.
To reassemble your device, just put it back together.
11 autres ont terminé cette réparation.
graham
Membre depuis le 08/21/13
350 Réputation
1 tutoriel rédigé
30 commentaires
Thanks just repaired my Lezyne Macro Drive front light. Light would flicker, just needed to re-solder the top left resistor shown in step 4.
richard taylor - Réponse
Thanks to your instruction I was able to fix my lezyne micro drive which had denied to work after short-circuiting the charging leads by accident. Just cut the battery and reconnected it - light was working again! Worked out nicely!
Thanks!
mongo - Réponse
Is it a 123 cell it takes? I will do this when I visit my father as he has a large vice. Thanks for the guide!
Aerotec - Réponse
Yes a "CR-123" cell 3V lithium ion
graham -
you can just push the electronics and battery out with your thumb. Usually the issue with these batteries is the battery contact gets slightly corroded. Clean it with battery cleaner, and twist the battery a bit for a new and clean connection.
scotdferguson - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 28
30 derniers jours : 120
Total : 34,194
