Aller au contenu principal
Lightahead DV328 Arrow Button Replacement
Ce dont vous avez besoin
  1. Lightahead DV328 Arrow Button Replacement, Arrow Button: étape 1, image 1 de 3 Lightahead DV328 Arrow Button Replacement, Arrow Button: étape 1, image 2 de 3 Lightahead DV328 Arrow Button Replacement, Arrow Button: étape 1, image 3 de 3
    • Use a spudger to remove the two screw covers.
    • Remove the two Phillips #0 screws.
  2. Lightahead DV328 Arrow Button Replacement: étape 2, image 1 de 3 Lightahead DV328 Arrow Button Replacement: étape 2, image 2 de 3 Lightahead DV328 Arrow Button Replacement: étape 2, image 3 de 3
    • Once you are able to lift the cover up, you will then be able to pry off the lens which will allow for the device to open more.
    • Take off the lens cover. Be careful not to pull the device open too much otherwise you will snap it in half since it is made of plastic.
    • Once you have this up, pull up the cover and you will now be able to work on the arrow key button
  3. Lightahead DV328 Arrow Button Replacement: étape 3, image 1 de 3 Lightahead DV328 Arrow Button Replacement: étape 3, image 2 de 3 Lightahead DV328 Arrow Button Replacement: étape 3, image 3 de 3
    • Lay the camcorder on its side. The arrow key button is now in full view.
    • There is a small green piece locking in the arrow key button. Once you remove that, the piece will be able to come out.
    • Gently push on the button and it will come out of the device. Replace as needed
Alexandra McMurray
Membre depuis le 01/20/16
355 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 10-2, Remmell Spring 2016 Membre de l'équipe USF Tampa, Team 10-2, Remmell Spring 2016
USFT-REMMELL-S16S10G2
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 193
